I had the Surf 200 for a while a while. Under usual circumstances conectin a worstation to the LAN it works nice.
HERE IS THE PROBLEM.
I have a remote datalogger with STATIC IP (192.168.1.131) (notice the 1.131) connected to the router (192.168.1.1) using the PepWave Surf 200. The Surf 200 obtains and IP let say 192.168.1.4 from my router. I need to FTP to the datalogger 192.168.1.131 from a workstation with IP 192.168.1.3 (for instance). Can you this be done? Can you help me with instructions how to achieve it?
±----------------------------------+ ±--------------------------------+ AIR ±---------------------------------+ ±-------------------------------------+
| datalogger: Static IP | | Surf 200 | /\ | Roter | | Linux PC - Datacolector |
| 192.168.1.131 | | IP on wifi 192.168.1.4 | / \ ^ | IP 192.168.1.1 | | IP 192.168.1.4 |
| Gateway 192.168.1.1 |RJ45=====| SET IP 192.168.1.129 | / \ / | Mask 255.255.255.0 |=======| Gateways 192.168.1.1 |
| Mask 255.255.255.0 | |NO DHCP server | \ / | | | Mask 255.255.255.0 |
Sorry for the confusion, the Surf 200 does not operate in bridge mode but rather only in NAT mode. You could try to setup port forwarding and see if that works.
The data logger obtained 192.168.2.130 IP from PepWave DHCP ((note the #.2. in the IP))
I manualy set the the IP on the device side to 192.168.2.129 (note the #.2. in the IP)
The pepwave obtained 192.168.1.2 (NOTE #.1. in the IP) from the router.
The router has ip: 192.168.1.1 (and runs DHCP)
The machine from which I am accesing it has a 192.168.1.4 (note the .1. in the IP) obtained from DHCP
Could you advice on how to set up the NAT? DO I set it on the pepwave device?
I did put the datalogger to the DMZ on pepwave
and I did put Papwave and the datalogger on the on the router to DMZ.
Curently I can ping the datalogger but CAN NOT FTP to it.
Once I get the MC 400 all I have to is plug it on and connect to the router and should be able to FTP to a an ip that has the same 192.168.1.x (#1) just the rest of the machines?
