How to I enable POE on the AP One 300M?
I have tried a 12V POE injector without success.
Went 5X over all the settings and the only manual I can find is the spec sheet that tells it can run on POE 12V
Any help is highly appreciated.
Rogier
Rogier
@Rogier, the AP One 300M only accepts standard 802.3af PoE input, not passive 12V PoE input.
Tim
So I can’t use the same one as I use for my Ubiquity AP’s and IP Camera’s ?
Do you have an example of the correct POE injector for me ?-)
Hi Rogier,
Any PoE Injector or PoE Switch complied to standard 802.3af should able to power up the AP One 300M.
Thanks and regards.
Here you go:
Of course I used the 12 Volt version
Hi Rogier,
I have checked URL given and the product datasheet, it seems these are not 802.3af compliance, as I found at their website for the 802.3af adapter.
Thanks and regards.
