Hello.
I got an IpSec between 2 peplink over internet.
I have many networks behind the peplink from the site A and only one network behind the peplink of the site B.
I can reach all the network from the area A & B, it works perfectly.
I want to keep internet on the site A but on the site B I am looking for how to disable it?
The lan of the peplink side B is a little network with a range DHCP of 5 IP.
I really need to disable completely the internet access and not only the http (port 80) or the https.
Could you help me ?
Best regards.
You should be able to accomplish this by setting the default outbound firewall rule to Deny on site B and then create allow rules for traffic that is destined to the networks of site A:
My site A got the network 11.0.0.x, 10.0.0.x, 20.0.0.x,30.0.0.x
The site B got the ip 80.0.0.x
So in the peplink B I deny the default outbound on the firewall and I allow only the rules like you specified remote access 10.0.0.0 / 24 ; 11.0.0.0 / 24 ; 20.0.0.0 / 24 ; 30.0.0.0 / 24
This will give me the possibility to disable the internet access, do you confirm?
Is it the only solution?
Many thanks for your answer I will try that tomorrow near 2 pm paris time.
Best regards.
I have set this config!! Answer tomorrow.
Many thanks for the advice.
