- Supported deployments
Standalone Peplink access points
Balance or MAX routers acting as a wireless controller managing Peplink access points
- Non-supported deployment
- Local build-in access point in Balance or MAX routers are not supported
- Following will be my network diagram
- On the above network diagram
I have a Radius server and its IP address is 192.168.52.200
I have a Balance 710 router and it is acting as a wireless controller to manage AC MINI
- Steps to configure 802.1X + Dynamic VLAN
Power on AC MINI and log into its web admin page
Go to ‘System’ > ‘Controller’ > ‘Controller Management Settings’
This will make sure AC MINI connect to wireless controller at IP address 192.168.1.1
Save the changes at AC MINI
Connect AC MINI to the LAN port of Balance 710 router
At Balance 710 router, log into its web admin page
Go to ‘Network’ > ‘LAN’ > ‘Network Settings’
Create 3 new VLAN networks
- The configurations at MANAGER vlan network
- The configuration at the STAFF vlan network
- The configuration at the GUEST vlan network
- Go to ‘AP’ > ‘AP Controller’ and enable the AP controller feature
- Go to ‘AP’ > ‘Wireless SSID’ and define a new SSID
Save and apply all the changes in Balance 710
At the radius server side, we need to add in 3 radius attributes in order to make dynamic vlan to work
Below are the 3 radius attributes that need to be added in the radius server
I have 3 user accounts inside the radius server
The first user account is ‘ohyt’ and he will be dynamically assigned to vlan 10
- The second user account is ‘tanjp’ and he will be dynamically assigned to vlan 20
- The third user account is ‘mary’ and she will be dynamically assigned to vlan 30
To perform the testing, I will be connecting to the SSID ‘DYNAMIC_LITE’ using 3 different accounts
When ‘ohyt’ is connected, he will be assigned to vlan 10 and obtain DHCP IP 10.0.1.10 / 24
- When ‘tanjp’ is connected, he will be assigned to vlan 20 and obtain DHCP IP 10.0.2.10 / 24
- When ‘mary’ is connected, she will be assigned to vlan 30 and obtain DHCP IP 10.0.3.10 / 24
- When ‘ohyt’ is connecting to the SSID, this is the handshake between Balance 710 and Radius server
- ACCESS-REQUEST from Balance 710 to Radius server
- ACCESS-CHALLENGE from Radius server to Balance 710
- ACCESS-ACCEPT from Radius server to Balance 710
- Whole authentication process is completed and user ‘ohyt’ is dynamically assigned to VLAN 10
