Hi - new to the group -
I can’t see how to do this - I am trying to delete an organization name that has a typo
Suggestions would be welcomed.
You could rename your organization’s name by pulling down the right most organization menu, choose Organizations Settings > Organization Settings.
If you want to delete an organization, just remove all devices from all groups. The system will automatically remove the organization 14 days later.
Thanks!
The reason I was puzzled is because I couldn’t access the “Organization Settings” menu.
What I didn’t realize is that the “Organization Settings” menu is not available until a group is created. Once I made a group, per your instructions I could edit the organization name.
I am having the same issue, and I don’t have any devices/group attached to my test organization. If I go to Organizations Settings > Organization Settings it asked me to create a group only.
Hi @hklossner,
You will need to create a Group first. Once you have created the Group you can then amend the Organisation name.
Hope this helps.
Steve
