I would like to setup a subdomain in PepLink 750, can someone help to guide me?
What do you mean by sub domain? Are we talking an Active Directory child domain?
Or are you talking about a smaller network inside your existing network (a VLan)?
jmjones, thank you for your reply.
It seems that all I have to do is to add an A record.
The story is I am using Mailgun service and was asked to create a subdomain and SPF/TXT record.
e.g. mydomain,.com is currently handling DNS service. Mailgun instructed us to create a subdomiain : email.mydomain.com
It turns out all I have to do is to create email.mydomain.com in DNS and set up TXT for email.mydomain,com
on the side note, when I edit the TXT record, I found peplink does not like cut-&-paste.
Gotcha - DNS subdomain. Glad you got it sorted!
