I want to eg change passwords, or enabled /disable a Celluar via the Bulk Configuration,
but i cant find how to create the config file to upload.
Regards
Holger
Regards
Holger
Work on a target device, configure it how you want. Download its config file once you have saved the changes and then use that config file in the bulk configurator.
