I’m trying to connect my Peplink Url logging to my Synology (model name: DS416j). Attached you will find some screenshot for both devices. The log is not being sent to my Synology.
Can you please advise how to solve it?
Thank you.
Thank you.
Hi
The peplink device will send in UDP and not TCP. If you change that in the log center settings on the synology then it should work.
I have tested this here and succesfully get logs this way.
James
Hi James,
Thank you for your reply. That solved the issue. The log is being saved now.
Best regards,
Joey
