Hi…
We have two units BPL 305 and BPL 310 I want to create VPN connection with this two unit.
Appreciate your helps.
Thank you.
Hi…
Thank you.
@Peds You can follow our user manual, page 71.
If you have router/firewall in front of Peplink, make sure port-forwarding is done for the following default protocols (TCP 32015, UDP 4500).
@Peds Sorry about that. I have meant to include that in my reply. =p
You can access it via our website > Support > Firmware and Manual Downloads > Firmware 7 > Balance and MediaFast User Manual for Firmware 7
