Good day. I just set up my first pep-link router (Balance 30). I jumped ship from SYSWAN. Setup went well and it is working, but after reading through the config options for load balancing I am not quite sure how to configure to achieve my desired goal.
CONFIG:
firmware: 5.1.5
WAN links: 2
LAN links 2
I want ALL traffic from one of the LAN links (192.168.10.2) to go through one particular WAN link (WAN1) ALL the time… except when the WAN link fails.
I want ALL traffic from the other LAN link (192.168.10.3) to go through the other WAN link (WAN2) ALL the time… except when the WAN link fails.
Again, only when the link fails do I want the LAN traffic to fail over to the other link.
I have set up two custom rules to achieve this, but of the choices: weighted balance, persistence, Enforced, prority, overflow… I am not seeing which one is right for my needs.
EDIT: I think the config would be to use WEIGHTED BALANCE for both custom rules, and set the desired WAN link to 100 and the other WAN link to 0. Please let me know if my guess is correct. I am assuming that such a config would auto failover to the link set to 0 if the main link fails.*
thank you for any tips!
jim
