Balance 210-A(DHCP)—Router—internet----Balance 210-B(Static Public IP,NAT)-----Balance 210-C
If we want to setup Point to Point PepLink VPN tunnel between Balance 210-A and Balance 210-C,how can we do it?
Custom Handshake Port:
Network - > SpeedFusion | PepVPN Settings:
Custom PepVPN Data Port
Edit SpeedFusion profile
Thank you MartinLangmaid.
In this environment, can I config the Point to Point PepLink VPN tunnel on IC2, or must I config it on each device end(click the network–> “PepVPN with SpeedFusion”–>“New Profile” tab).
I know you can set a custom data port but I don’t think you can set a custom handshake port. I’m sure @Michael can confirm that either way if we ask him nicely
Martin’s right, a custom handshake port is a feature that isn’t currently available.
Since the handshake port is global to all profiles on the device, we can’t allow it to be set through the existing pepvpn management UI.
