How to bridge wan port
#1
hello support
how to bridge wan1 port to wan2 port?
thanks
#2
Can you explain what you mean?
#3
for example the ISP give /29 block of public ip so in wan1 will be the connection coming from isp then in wan3 i put another machine which required also a public ip
#4
This can be accomplished using the drop-in mode functionality on the Balance 210 or above and would be on the LAN side not on a WAN port:
