Hello and Good Day
What’s the best way to block Amazon Web. Services from showing up, I see their IP address in active sessions sometimes, and I have not one thing using AWS.
Using the Surf soho MK3, with latest firmware.
Thank You
Hello and Good Day
Thank You
Hello @Ballistic,
Are you using InControl2, if so this is hosted in the AWS platform, that may be what you are seeing.
What is the IPs at AWS you are seeing?
Happy to Help,
Marcus ![]()
Hello mldowling
Yes I use IC2. So I best just leave well enough alone.
The IP is 35.166.227.55, 35.166.277.48 and the such.
Thank You for the reply
Here you can find a list of the IP addresses used by IC2:
Hello @Ballistic,
This is in the list mentioned by @aldwinaldwin & published by @Alan.
This could be another service on your network needing access to AWS. AWS is used by lots of companies now for their cloud services. Look up the details of the IP using a Reverse DNS tool.
Happy to Help,
Marcus ![]()
Thank You both
