How to allow two devices on the Same VLAN to see each other
I have a few VLANs set up on a Peplink SOHO MK3 running firmware 8.3.0. Each VLAN has its own SSID.
On VLAN-1 there are two devices, device-A and device-B, both connected to the same SSID. I would like to be able to ssh from device-A into device-B…
Connecting these two devices to a completely different router, device-A can ssh into device-B. But when i connect these devices to VLAN-1 on the peplink, calling ssh from device-A to device-B says “unreachable”. Ping fails with timeout.
I have made sure that “Block All Private IP” is NOT checked. I’m not sure what else to try, I’ve looked through all the settings and I do not see anything else that would prevent these devices from seeing each other. Correct me if I’m wrong here, it was my understanding that by default, devices on the same VLAN can and do see each other.
Hello.
Please… check inter-vlan routing…
Screenshot 2024-11-01 11.50.20
@MarceloBarros I checked inter-vlan routing and they still do not see each other
Please…
Check Layer 2 Isolation and disable it.
To see this option… go to ssid settings, choose " ? " and enable advanced settings.
and about
" Connecting these two devices to a completely different router, ".
Can you draw what are you doing? This router? it is a Peplink?
To see this [Layer 2] option… go to ssid settings, choose " ? " and enable advanced settings.
Oh that makes all the difference. Thanks for pointing that out! We are connected now :slight_smile:
:question: Are there any other hidden settings in the router? I hadn’t thought to try clicking all the question marks to see what was in them.
Yes… there is a few…
Sample…
