I have Peplink B one 5G and I have inserted 2 SIM cards into it. I want both SIMs to be connected at the same time (two different LTE providers). Unfortunately, only one SIM card is always in USE. I would greatly appreciate any help.
Hi…
Peplink B-ONE, just have um LTE MODEM, so… just one SIM CARD can be used at the time. ( 1 x Embedded Cellular Modem with a Redundant SIM Slot )
For TWO SIM CARDs at same time… You need a device like BR2 PRO 5G.
Thanks for your reply.
If I add the MAX Adapter 5G can I have a second 5G connection ?
Yes, the 5G Max Adapter (the awesome small plastic one) will work.
