How much does the 82G weigh?
Weird that no where in the datasheet is the weight of the 82G listed unless I missed it.
It depends on the cables and connector types. It is not mentionned in the datasheet and for most verticals it was designed for, this piece of information is irrelevant.
And now you have triggered our curiosity…
@FrontierComputerCorp any unit in stock to check?
I am looking to attach the 82G to a tripod outdoors and connect it to a BR2 router for streaming sports games. Does that help? On another thread i was told it was 3.1 kg.
For completeness it is as you said 3.1KG. Here is the link to the other thread.
https://forum.peplink.com/t/mobility-82g-constant-mission-critical-signals/650bb96f47cc7968007ffd27/4
