How i can reset the password on the peplink device, if i dont have any lcd button and nothing
What model device? Smaller units have a reset button in a hole that needs a paperclip to reset it. Larger ones have a LCD with buttons.
thats the problem i dont have a device
Sounds dubious to me. If you could remotely change a router to the default credentials, what will stop anyone from logging into your router? That’s why you can’t do it if you don’t have physical access. Please explain.
