How can I get a Peplink Fusionhub trial key? Can i use it with Peplink Balance 1350 for WAN load balancing on my remote server?
Please refer to the user manual below.
Believe you are referring to establish SpeedFusion Bonding between Balance 1350 and FusionHub. Yes, this is supported. Please start your FusionHub from the URL link below.
