Its a choice when setting up an SSID, but there is this grey text under the pick-list that says: “This SSID will only be applied to AP with WPA3 supported”. So that makes me ask if my internal AP supports it? Freaking iPhones don’t want you to know how its connected and the status page on the Transit for clients doesn’t show a thing other than its connected to my test SSID that only has WPA3 Personal enabled…
