I’ve seen various articles, posts, etc on how to do this and I’m just totally lost on how to get to the Starlink dishy management app once in ByPass mode. And it seems that things have changed since old posts on both the Peplink and Starlink sides. Can anyone share a screenshot of how they have set up the IP routing and then what link to use to get to the management screen (dishy.starlink.com??).
I have a B One with Starlink Gen 3 connecting the router via Ethernet and in ByPass mode. There are some management features I’d still like to be able to.
I’ll attach what I’ve tried based on others I’ve seen.
I have found an useful dishy management page at 192.168.100.1! I’m using a Peplink MAX BR1 Mini (HW3) with the management IP address of 192.168.100.100.
I have a B One 5G connected via Starlink with the starlink router in Bypass mode… Not sure if this is what you’re after but, I literally just hit the Starlink App from my phone connected wirelessly to the B One 5G AP and can manage the Starlink dish from there. Stow, reboot, look at obstructions etc etc
If you want the starlink and ic2 notification integration you need to login to the network → wan and check the starlink wan interface of the one you want to enable.
I missed your response when you first posted it. I tried it and it worked - thanks!! Next time I have obstructions, I’ll see if it gives me more information on that.
I also missed your reply when you posted it. It wasn’t working at first, but since you said you were able to see it, I kept trying. Found out what was causing my issue. I could get to some info by clicking on the “head” (account) information but clicking the Starlink device to manage it wouldn’t work. Then I noticed on the main page of the app that it was prompting me to set up a new Starlink. I didn’t need to do that since it was already set up, so I ignored it. This time, I chose “skip” and then it gave me exactly what you showed Thank you so much!!!
