I have a BR1 Pro 5G X65 router. I am trying to connect my router to the antenna (Poynting A-MIMO-0003-V2-17). The ports on the antenna are labeled Cellular 1/Main, Cellular 2/Main, Cellular 1/Auxillary and Cellular 2/Auxillary. The router ports are labeled Cellular A thru D. Which router port is connected to which antenna port?
It doesn’t really matter because all four antenna elements are the same. Just make sure all four are hooked up for the best performance.
