High Availability Speedfusion Connect Require Primecare?
Do both routers require a Primecare subscription when setup for High Availability and using Speedfusion?
Hi…
Are you writing/asking about?
BR1? BR2? BPL?
What product will you use?
The B One 5G and Balance 310 5G.
Hello…
Take a look at:
310 5G:
About High Availability:
B-ONE-5G: High Availability: Yes ; no primecare license
310-5G: High Availability: Yes ; no primecare license
Thanks Marcelo, When you have 2 units in HA, for example the balance 310 5G, do both the primary and HA device require a PrimeCare Subscription?
Hello, Rob1.
Yes, both units must have Primecare up to date.
and for High Availability, both need to be the same model.
okay?
