Kindly if you can advise if the below feature is supported with the Max BR1
How Does Hide NAT Work?
In Hide NAT, traffic to and from the internal networks traverses an enforcement module. When a packet from an internal network passes through the gateway, the source IP address is changed to the hiding IP address, and the source port is changed to a dynamically assigned port that uniquely identifies the connection. The relationship between the dynamically assigned port and the internal IP address is recorded in the gateway’s state tables. When reply packets arrive, the enforcement module uses the destination port to determine to which connection the packet belongs, and then adjusts the destination port and IP address accordingly.
