Our radio stations do a lot of remotes over 3G/LTE networks. We are searching for a reliable solution which will help us to have a stream without interuptions. We don’t transfer a large amount of data, but low latency is crucial. Which products would you advise to us?
You can use either a MAX HD2 or MAX HD4 for remotes, and a Balance router or FusionHub for your radio station.
As per the diagram, with Peplink at both end they are capable of establishing a connection with one another using all of the available WANs, only possible with our unique SpeedFusion Bonding Technology.
