Before I go messing around too much with my Peplink, I’d like to get some input on what I’m proposing to do since this is new territory for me.
Problems
- I’m running out of IP addresses. I mostly use DHCP Reservation on my network for my Macs, Printers, iPads, Voip phones, network scanners, IP Cams. I also have several WAPs that provide a private network and a guest network. I’m hovering around 200 devices now and expect that in the next year I will go above 255. So, my single subnet is going to run out of addresses
- With the growing number of devices, i’d like to make sure i’m doing what I can to optimize network performance.
Hardware
- Peplink 305
- A Netgear 48 port switch - GS748T
- A Netgear 24 port POE switch - FS728TP
- 2 TP link 8 port POE switches that I also have just sitting around
My strategy
- I’m planning to put all my computers, printers, scanners, and NAS onto the 48 port switch and have them on 1 subnet.
- My VOIP phones are all POE and I’d plan to put them onto the POE. The phones do not need to communicate at all with anything else on the network and their traffic should be given high priority.
- The IPCams and WAP’s that I use for the guest wifi network are all POE, but I’d like to plug them into a separate POE switch that is not on UPS power backup. The 2 switches above and the Peplink are on UPS. I would like to deny the guest wifi users access to any other part of the network. I also want to do everything I can to prevent a guest bandwidth hog from affecting my phones and network in general.
The IPCams, however, are controlled by the NAS on switch 1 which also acts as an NVR. Notably, the NAS does have 2 ethernet ports and it may be possible to connect 1 port to the switch 1 and the other port to switch 3 instead of requiring the video traffic to be routed across the switches.
4. Next, I have 5 Peplink WAPs for my private network that need to be kept as low latency as possible, support numerous high bandwidth ipads at a time, and be connected to backup power. I figure they could be on the other TP link switch.
5. Finally, I have about 15 sonos speakers. they are just plain taking up a lot of IP addresses. Not sure where to connect them. The computers and ipads need to be able to connect to them to change music.
Setting up multiple subnets will give me the IP address space that I need, but am i otherwise making this more complicated than need be? Will segmenting things among the switches and subnets lead to any significant performance gains?
I’m very open to suggestions here.
