I have a home setup Surf Soho Mk3 setup with a wired WAN to Starlink and Wifi over WAN to a 4g hotspot. Starlink alone is fast but it suffers from intermittent dropouts which cause issues with Zoom, Teams etc work and school calls.
My objectives are (irrespective of the client):
- Route VOIP only traffic to SpeedFusion cloud, bonding both the Starlink and 4g connection.
- Route everything else to Starlink as 1st priority and 4g as backup
Setup is
- WAN connection status is WAN and Wi-Fi WAN on 5ghz as Priority 1
- SpeedFusion Cloud WAN connection priority is WAN as Priority 1 and Wifi WAN as Priority 1, i.e. bonded
I have tried to set the outbound policy to route all supported VOIP or Zoom to SFC, following the instructions. This does not seem to work. The only way I have been able to route traffic to SFC is to create a default custom rule to either enforce or prioritize SFC but then of course all traffic gets routed to SFC. It does work as expected, however, on Zoom etc and I can see both connections being bonded in Status page.
Reading this topic, it seems like what I’m trying to do isn’t possible? SpeedFusion Cloud vs FusionHub - tunnel profiles - #3 by stevemitchell
If so, is there another way I can achieve what I am trying to do?
Many thanks in advance!
