Help With Multi Site VPN - Balence20
Hello All,
I have a 2-site office both having Balance20 routers. I have an IPSec tunnel between the two. My question is one office has an IPSec tunnel to remote location to a specific IP address /32 from a specific laptop static /32. The laptop moves from one office to the other. I’m not sure I can set the same VPN tunnel at both offices. Is there a way to use the VPN at office A when the laptop moves to office B? Any suggestions?
Don’t do that! Us PePVPN instead much easier and better than IPSEC…
Hmmm tricky. I would try using PepVPN for the site to site, then the IPSEC to the remote device will be advertised to both routers over PepVPN (using OSPF). So any device can access it from either Balance 20 LAN so long as you let the remote IPSEC connection know about both LAN subnets.
