Hi Peplink Community ,
I’m working on establishing an IPSec VPN between two Peplink B One devices and running into some trouble.
Scenario Overview:
- Branch Location (Santo):
- Device: Peplink B One
- Goal: Initiate IPSec tunnel to HQ.
- Internet is working fine.
- Headquarters (Vila):
- Device: Peplink B One 5G
- Setup: Acting as a bridge to a FortiGate firewall.
- The FortiGate is doing the main routing/NAT/firewall duties.
Issue:
The IPSec VPN is not establishing between the two Peplinks. I’m assuming it has something to do with:
- The HQ B One being in bridge mode, passing traffic to the FortiGate.
- Possibly some issue with NAT traversal, policy, or forwarding.
What I’ve Tried:
- Verified IPSec profiles match on both ends (PSK, phase settings, etc.).
- Ensured public IPs are correctly configured.
- Allowed IPSec ports (UDP 500, UDP 4500) on the FortiGate.
- Tried initiating the tunnel from both ends.
What I Need Help With:
- Has anyone set up a similar IPSec VPN with a Peplink in bridge mode behind another firewall (like FortiGate)?
- Should the VPN be terminated on the FortiGate instead?
- Any special routing or NAT configs needed to make this work?
Appreciate any suggestions, configuration tips, or working examples!
Thanks in advance
— Albert
