Home user since 2018, still in the foothills of the learning curve.
I’ve been having the occasional “connected no internet” on my wireless network (on firmware 8.1.2). These increased to multiple times/day after upgrading firmware to 8.1.2s052.*
I checked the event log after one of the outages and found many instances of
“WAN disconnected (WAN failed DNS test)” most lasting seconds to minutes. Devices reconnect automatically. Below are the disconnects/reconnects from the event log. [ISP’s IP replaced with text]
Is this likely a router setting problem, and ISP problem, a DNS provider problem, or something else?
Aug 03 14:15:57 | WAN: WAN connected (ISP IP address) |
Aug 03 14:15:22 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 03 14:14:42 | WAN: WAN connected (ISP IP address) |
Aug 03 14:12:09 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 03 11:11:24 | WAN: WAN connected (ISP IP address) |
Aug 03 11:10:58 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 03 10:14:23 | WAN: WAN connected (ISP IP address) |
Aug 03 10:14:03 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 03 09:59:24 | WAN: WAN connected (ISP IP address) |
Aug 03 09:58:59 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 03 09:57:59 | WAN: WAN connected (ISP IP address) |
Aug 03 09:56:26 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 03 09:54:21 | WAN: WAN connected (ISP IP address) |
Aug 03 09:54:05 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 20:31:01 | WAN: WAN connected (ISP IP address) |
Aug 02 20:30:51 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 19:08:46 | WAN: WAN connected (ISP IP address) |
Aug 02 19:06:12 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 19:04:51 | WAN: WAN connected (ISP IP address) |
Aug 02 19:02:46 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 18:56:37 | WAN: WAN connected (ISP IP address) |
Aug 02 18:56:02 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 18:36:22 | WAN: WAN connected (ISP IP address) |
Aug 02 18:36:12 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 18:29:17 | WAN: WAN connected (ISP IP address) |
Aug 02 18:29:07 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 18:28:02 | WAN: WAN connected (ISP IP address) |
Aug 02 18:27:52 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 18:26:12 | WAN: WAN connected (ISP IP address) |
Aug 02 18:23:31 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 18:21:25 | WAN: WAN connected (ISP IP address) |
Aug 02 18:21:00 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 17:54:36 | WAN: WAN connected (ISP IP address) |
Aug 02 17:54:06 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 17:51:00 | WAN: WAN connected (ISP IP address) |
Aug 02 17:50:50 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 17:39:26 | WAN: WAN connected (ISP IP address) |
Aug 02 17:39:01 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 02 08:22:47 | WAN: WAN connected (ISP IP address) |
Aug 02 08:22:26 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 01 21:19:42 | WAN: WAN connected (ISP IP address) |
Aug 01 21:19:17 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 01 21:14:42 | WAN: WAN connected (ISP IP address) |
Aug 01 21:14:12 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 01 20:19:42 | WAN: WAN connected (ISP IP address) |
Aug 01 20:19:32 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 01 19:52:37 | WAN: WAN connected (ISP IP address) |
Aug 01 19:52:07 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 01 19:06:37 | WAN: WAN connected (ISP IP address) |
Aug 01 19:06:11 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 01 19:05:46 | WAN: WAN connected (ISP IP address) |
Aug 01 19:05:26 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 01 17:11:02 | WAN: WAN connected (ISP IP address) |
Aug 01 17:10:47 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 01 17:04:07 | WAN: WAN connected (ISP IP address) |
Aug 01 17:03:47 | WAN: WAN disconnected (WAN failed DNS test) |
Aug 01 16:42:04 | System: Time synchronization successful (0.pepwave.pool.ntp.org) |
Dec 31 19:01:39 | System: Started up (8.1.2s052 build 5022) |
*8.1.2s052 fixed my connectivity problems on the camera 2.4 GHz WiFi network so don’t want to roll back.
