Need to connect an AP One Rugged to my Max Cat18 via Ethernet cable no clue how to set it up in the Max Control software to use it as my RV Internal device AP. Leaving my Max Cat18 connected to external campground Wan WiFi only. Help please.
Here’s my attempt at shorthand for what you want to do…
On the MAX Cat 18
- AP (Top Menu) → Wireless SSID (Left Menu) → Enable management of external APs
- AP (Top Menu) → Wireless SSID (Left Menu) → Create a new SSID you want to use
- Plug in AP One Rugged to LAN
- Watch it connect under AP (Top Menu) → Access Point (Left Menu)
Thanks so much…will give it a try…
Jeff
