Help with 3 Site Network
I need some advice or professional services to setup and configure a new installation. I have a beginner to intermediate level of experience with this technology but am comfortable with configuration.
Here is the scenario:
  • 3 sites
  • Site 1: main office with symmetric 500Mbps fiber and Peplink B One 5G (planned)
  • Site 2: home office with 100Mbps up / 500Mbps down cable and Peplink B One 5G (planned)
  • Site 3: mobile (maritime) with Starlink, cellular, and sometimes WiFi WAN with MAX Transit Duo Pro (to be upgraded MAX BR2 Pro? (TBD))
  • Objective: Site 3 (mobile) connects to Site 1 (office) via SpeedFusion/VPN such that all Internet traffic is via the Site 1 WAN. Site 3 also has the ability to access Site 2 (home) like it is on the same LAN for access to local devices. Site 2 does not need any direct connection to site 1 and vice versa.
I am looking for direction on optimal topology and also recommendations on hardware if the selected products are not the best ones.
Thank you.
Hi…
Just comments…
B-ONE <> BR2PRO <> TST-DUO-PRO
site1: NICE…
site2: NICE…
Site3: So… You have a Starlink and the tst-duo-pro is dual cat lte-12. I will keep it and not replace by MAX BR2 PRO.
Objective:
Site 3 <> SpeedFusion <> Site 1. Why send all the internet traffic to site 1?
Site 3 <> SpeedFusion <> Site 2. Site 2 have a fixed public ip address?
Regards, Barros.
Thank you for the reply, Barros!
The reason to send all traffic from Site 3 via Site 1 is because some country- specific services will not work when Site 3 is located outside of my home country. This will make it appear Site 3 is in my home country at all times.
Site 2 does not have a static WAN address. DDNS is possible, however.
My thoughts behind upgrading the TST-DUO-PRO is to gain 5G support and to increase the number of LAN ports.
okay…
So…
MAX-BR2-PRO-5GN-T-PRM (GLOBAL)
OR
MAX-BR2-PRO-5GK-T-PRM (North America*)
  • AT&T, T-Mobile, Verizon (C-Band), FirstNet
Thanks!
Any advice on the topology?
no… I think it is simple, but works.
