Hello Gents,
First, let me clarify I’m not Tech savvy, Just can handle the basics… so any step by step explanation will be appreciated…
I just bought this Pepwave Max on the go based on the poor performance of my internet cable connection, So I bought 3 USB modems and have the user and password of my friendly neighbor wifi network…
So this was my mental process to get this post finally:
- This pepwave device it’s supposed to merge 3USB modems (3 Mbps each) + DSL (0.75 Mbps) + external (neighbor 1Mbps) <---- am I right to this point???
2)If I’m correct then I’ll get from the Pepwave max 3x3=9Mbps + 0.75 + 1 = 10.75 Mbps concentrated in my recently created AP from the same device…(I’ll be happy with that)
3)Then I set up the neighbor WiFi Parameters, connected the 3 USB modems and connected DSL cable…
- Created my brand new access point…
RESULTS…
When I get into the dashboard and try to drag every recently created connection to “priority 1” just one remains active while others change status to stand by or disconnected… never can have all the ISP merged into a single connection and add each broad band as expected…
I’m trying this to my home network, nothing so complicated…
My thoughts are correct or there is something I’m missing???
Do I need to configure something under the VPN tab??? honestly I don’t know how to do it? can you please provide step by step instructions please???
