I am trying to replace the standard Starlink router (UTP-221) that comes with the Starlink High Performance Flat Panel (Marine/In-Motion) kit so I can power the dish directly from my Airstream’s 12 VDC. I have been trying to do this conversion for the past year with various components and configurations, all with the same results.
This is the current configuration:
I have this Yaosheng 320W POE injector that supports 48-56VDC:
YAOSHENG 320W PoE Injector for Starlink HP (Starlink High Performance) : Amazon.ca: Electronics
To power the POE injector, I have this DC-DC converter:
DC-DC Voltage Step Up Converter Boost Module 10-60V to 12-97V 1500W 30A CC CV : Amazon.ca: Electronics
And the router is a recently purchased Peplink BR1 5G PRO. In the router, Starlink is set up as WAN1.
When everything connected and powered up, this the behavior I see:
1. The POE injector LED is a solid green.
2. Peplink attempts to connect to Starlink, displaying the WAN status “Connecting… (No IP Address)” for about 10 seconds
3. Peplink then displays “Checking Connectivity… (206.214.239.194)” with for about 20 seconds
4. Sometimes Peplink will display “Starlink Outage (Booting)” for 5 seconds
5. Peplink then displays “No Cable Connected (No IP Address)”. Sometimes there is a Starlink icon, usually there is no logo.
6. At the same time, the POE injector flashes a fast red and yellow about 8 times, then flashes a slow white about 4 times
7. About 30 seconds later, this entire process repeats with “Connecting…”
The POE LEDs seem to be indicating a undervoltage input to the POE when the HP dish is trying to reboot (I assume). I know it has been noted that this Starlink HP panel may have large current spikes during reboot.
I got the current variable power supply to try different voltages. It is set at 56 VDC to overcome any upstream voltage drops; I had read that the dish itself can accept 48-56 VDC input.
If I skip the POE injector and plug the dish directly into the original Starlink router (powered with 120 VAC), and then connect that to the Peplink router WAN port, THIS WORKS as expected.
I have tried (all with the same results):
- Putting an unmanaged switch in between the POE LAN port and the router WAN port
- Changing the router port speed (auto, 1Gbps, 100 Mbps)
- Replacing the DC-DC converter (4 so far)
- Changing the power supply voltage (tried everything from 48VDC to 56VDC)
- Replacing the POE injector (4 different models so far)
- Tried different POE types, like the one requiring custom RJ45 wiring
- Replacing the router (was using a MoFi 5500 previously, the Peplink is much easier to configure)
- Checked and replaced cables and connectors, using CAT7 where necessary and ensuring shield/ground connections
I have spent a lot of time (and money!) trying to figure this out without luck. Does anyone have any insights?
