Starting - Usually means it can’t find the other device but is ready
Updating Routes - Found the other device, learning the multiple routes. In our experience, the more WANs, the longer it takes except for the HD4, its usually very quick on this stage! (Usually between 10 and 30 seconds. Sometimes up to 90 seconds)
Established - Fully connected
How long are you stuck on Updating Routes?
If its stuck on updating routes you might have a subnet clash. You can’t have the same LAN subnet at both ends with the default settings for a Layer 3 PepVPN.
The only time you can have the same subnet at either end of a PepVPN tunnel is when you use a Layer 2 profile and so are transparently extending the LAN of one device at a location to the LAN of the other device at a different location.
I have no idea what you are talking about.
All I want is to archieve what Peplink promissed me. A “LAN” connection via the internet so I can access the drives from a remote office.
As soon as I can afford to change the LAN IP on my side I will give it a try.
It will throw IOT’s and server off my network so I have to find the right moment to do this.
Yess I finally have green lights :o
The trick was to assign a different LAN iP range on one of the routers.
Now I am still disapointed :mad:
I was promissed that this PEP VPN would act as a ethernet extention trought the internet and that all my local drives and resourses would be available.
Not so. When I run my iP scanner I only se the addresses from one side.
No server and shared drives are showing in Finder either.
