We need some helps with Starlink High Performance Flat with Peplink B One 5G.
Observed behavior
When WAN Health Check is enabled, the connection test fails. In this state, we cannot reach the Starlink antenna web console at http://192.168.100.1 from the LAN.
If we disable WAN Health Check, the WAN shows “Connected” and we can then reach http://192.168.100.1.
I can reach the antenna page using a browser launched from a mobile device, but on the same device, when I open the Starlink App, it will not detect the Starlink antenna.
We need to connect to the Starlink Antenna to check on the status especially when it is not able to connect.
