Hi Guys, compared to most of the discussion on here, you’ll probably roll your eyes, but here is the deal:
I have a MAX BR1 MK2 and another router sitting behind. Even though I have configured ‘IP Passthrough’, it still seems to be natting, which doesn’t make sense to me. I literally just want the Pepwave to be a dumb transparent modem so that I can use my router sat behind it for all the management.
I am a home user for this issue, but I work in IT security. I live in a very rural place but get excellent Cell signal. I am changing from Satalite to ATT using a pepwave. Everything works fine, except Xbox live. The xbox constantly complains about Double NAT when using the Pepwave and my router.
As far as I can tell, the ‘IP Passthrough’ option should resolve my issue.
Any help is appreciated!
