We have two fixed wireless links coming to one location. Both are from the same ISP. Can we use the balance 305 to provide good fail-over?
The provider has multiple subnets available.
Thanks.
Thanks.
Hello jdhurd,
Both WAN connections should be fine on the same subnet. You just want to make sure the LAN is on a different subnet.
Do you know the time to failover using the balance 305?
Thanks.
Times for WAN fail-over is depending on the WAN health check settings defined. Detail info please refer to knowledge-base link below:
