I have two Pepwave units in my RV. A MAX BR1 MK2 as the primary with a BR1 MINI, each of which has one SIM in it for cellular (AT&T and Verizon respectively). I want two networks active at the same time and this seemed to be the most affordable way, both units are LTE-A models. My question is whether or not I should disable health checking as there are two networks playing together in weighted balance and only one SIM in each unit. It seems to me the health checking is adding processing power and when a health check fails (I have it set to 1 bar) it’s just unnecessary processing power to fail it. The other thing is that it’s only one source that’s not in the disabled slot in both devices, I’m not using WiFi or any other WAN so I’m not sure health checking should even be in play for that reason.
My main question so I don’t digress is with two Pepwaves, each with 1 source, should I disable health checking per my config above?
Thanks.
