I’m connecting a HD2 Mini to a sim injector using SimCloud.
Inside the HD2mini i’m using 2 physical sims with expensive rate that are used for the simcloud connection only.
To avoid consumption on these sims while testing, i added to route all trafic to a deadend (wan), and keeping only traffic to peplink.* to the cellulars.
According to the diagnosis, Simcloud cannot be be contacted : ERROR_SIM_BANK_NOT_FOUND .
The FusionSims load correctly as soon as i plug an active WAN or remove the outbound rule.
Could you tell me if the connection to simcload is using another domain that i sould whitelist ?
Secondary question:
Would it be possible to define different kind of rules depending on the Sim (if it’s remote fusion sim or physical sim): outbound rules / pepvpn rules / …
I really need the traffic to only be allowed using the Fusion Sims and not the physical sims.
