Hd2 dome installation
Hi all,
Does everybody know the screw metric of Ethernet Input/output ports referenced the following image:
According to the information appeared the DC POWER is not included, so it must be prepared. Do you have more information about this?.
Thanks and best regards,
No power source is included with the DOME product range.
The router is powered by PoE so there are no DC power inputs.
The ethernet ports have a M20 thread.
Hi Rosa,
Additionally to Sam’s comment you can see how the Dome is set up and powered with POE in this video.
