I’m curious if the HD1 Dome Pro, when plugged into a WAN port on a Balance One 5G, can also access a SIM inserted in the Balance One 5G unit and avoid the need for a SIM injector?
no it can’t. Your options are to use a local sim injector or a hosted FusionSIM appliance to virtualise a physical SIM card into the dome.
Or you can send an eSIM of course.
Thanks @MartinLangmaid That’s what I figured the answer would be but was certainly hoping it would be supported.
