Hi Everyone! I am looking for the most economical Peplink Router Model to use Hardwired WAN from the local ISP as the Main and Starlink as the Failover. Thank you!
Hi, @safetypin117
Welcome…
You can look at the model comparison table
Sample… (enterprise)
or
Just take a look for a device with two wan and the Stateful Firewall Throughput can reach of both internet connections together.
Example: Starlink (200mbps) + Local ISP (300mbps) the minimum throughput should be 500mbps.
How many users?
You could use anything from a B-one , 310 fiber, or 580x.
Thank you for getting back to me, Jonathan, and Marcello. I need this for a security application. I have Cameras constantly streaming to the cloud, and I need to use Starlink as a failover in case the main ISP is down. Max 50Mbs. Most cases would be like 10-20 Mbs. No need wifi. What would be the most economical device? Basicaly needs to support 2 WAN and one Sim (optional)
Looks like Balance 30 LTE or Balance 30 Pro will do the job.
I would have a look at the B One
Hi…
Sorry… both devices are EOL (End Of Life)
take a look at
B One is an excellent device for this. I’m using one with fiber as WAN1 and Starlink as WAN2. Powerful and very economical. Strongly recommended.
Thank you! What would be the price?
please contact your certified Peplink Partner to get a price.
Please tell us where you are so a Partner who serves your area can contact you.
