Hardware Recommendations
I currently have a Balance 20X on the main level and an AP One AC Mini on the second level. I would like to upgrade our networking equipment to address two issues, and I’m looking for any advice or suggestions.
  1. We have a 1 gig fiber connection, and I would like a router that can handle a symmetrical 1 gig connection. The Balance 20X seems to top out at 400-500 Mbps throughput (out the WAN) in my testing, though it consistently gets 900+Mbps throughput within the LAN. (All tests performed via Ethernet.) We don’t need cellular capabilities.
  2. I would like to upgrade the Wi-Fi on our premises to provide Wi-Fi 7 throughout.
In the real world, would the B One provide symmetrical 1 gigabit WAN throughouput?
If not, what’s the next most affordable option to get that level of WAN throughput?
Does Peplink have (or is Peplink planning to release) a router that has Wi-Fi capabilities comparable to the new AP One Enterprise (2026) that supports Wi-Fi 7?
I was thinking about getting a pair of AP One Enterprise (2026) access points, but it would be nice if I didn’t have to pay for the Wi-Fi components of a new router (e.g., the B One) when I don’t plan to use them.
Thanks for any suggestions.
I did a fair bit of bench testing on a B One 5G when I had a spare around (all currently deployed, can’t do further testing atm). I didn’t specifically test 1 connection, 1Gbit symmetrical, I was testing throughput of the device in general and specific USB dongles. In my multi connection, multi system testing I was only able to push 1.4Gbit or so WAN to LAN. I would be very surprised if it could handle much more than that. It’s possible someone has tested this but it is twice the rated throughput.
You could try the B One and see if it’s enough for your needs (few people are ever actually maxing upload and download simultaneously). This is certainly your cheaper route.
Your next step up puts you at the new version of the Balance 310 (not x or 5G or other versions)
It jumps to 4Gbit router throughput, dual 2.5Gbit WAN and 4x10Gbit LAN and has no built in WIFI. You would then need 1 or 2 of the AP One Enterprise (2026) models for coverage.
This would give you a fair bit more future expandability both internally and for future internet upgrades.
Before ordering anything, I would advise talking to a sales rep at your sales company of choice. It is likely that they can put a package deal together and make advisements. Also occasionally they have used (demo or returned units) and might be able to sell you a used B One with the understanding that if it doesn’t meet your needs they will restock it and sell you a Balance 310 (or other unit) within their return window.
