Is it possible to setup HA when the two peplinks are both 380 but one is a different hardware revision (I assume the firmwares have to be the same).
Hi Wim,
It is absolutely acceptable to setup HA between different hardware revisions of the Balance 380. You are correct that they would still need to be on the same firmware release.
Thanks, just wanted to make sure.
