We are running into some serious management issues with our hub SDX-PRO routers, which have between 500 and 800 speedfusion profiles and upwards of 1200 static routes or outbound policies and some grouped networks with many entries.
The issues are not bugs - the router is working as designed. Rather they are evidence that although an SDX-PRO can handle 800 SF peers and an EPX 4000…no one on the GUI dev side has actually USED one with that kind of volume in use. Frankly, I cannot imagine managing thousands of peers/routes etc the way it is now.
I am going to break this up into multiple requests, as there are five different ones I would like to see, but they are unrelated to each other, other than that they are about capacity.
#4 the outbound policy page
4a - add a filter search to find a route in question. It can be difficult to find the right one out of hundreds
4b - on an individual outbound policy, when you are trying to set enforced or priority to a VPN, and you have hundreds of VPNs it is VERY difficult to pick the right one.
Again - allow for a filter search
We will evaluate this. Thanks for your feature request!
Agreed this is badly needed!
Can we get a final response and timeline on this?
