I’m using a Peplink Max BR1 Mini which had been working fine for months. Now green light blinking. Read thru previous posts and have: made sure the Verizon SIM is inserted gold contacts down in A slot; using roof top antenna with all connections tight at back of Mini; tried both reset and unplugging and reconnecting power. None of these attempts worked.
I have a Kenwood CD player/ stereo in the same box as Mini, but this hasn’t been a problem in the past. That said, I disconnected the stereo and removed it from the box and the green light continues to blink.
I do not have an Ethernet cable and I’m on the road in a camper van.
What should I try next?
Thanks so much for your time and help!
Rocky
