Hi Team
Is possible to configurate a GRE tunnel with the MAX BR1( firmware 6.2.0) ? if not which do you recommend? to have a tunnel source and tunnel destination
Hi Team
This is on our road map and we may have a special firmware available. If you could create a ticket with us I can certainly get things over to engineering to discuss.
Is it possible now to configure a GRE tunnel with the MAX BR1?
@MartinLangmaid Thansk for your answer. Does the configuration attach a MAC address to the GRE tunnel? (like mapping the ethernet port MAC address to the GRE tunnel)
Actually I don’t know @WeiMing might…
@dlawrence, GRE configuration doesn’t require MAC address. Do you mind to elaborate more on the statement and share your deployment scenario?
Hi @WeiMing, Thanks for the answer. I need to map both IP and MAC address to the GRE configuration. The MAC address mapping is important for me (Like this instruction Layer 2 over Layer 3 using Linux built-in features).
@dlawrence, are you looking for something that could be achieved via our Layer 2 SpeedFusion, as explained in one of the article?
@WeiMing, yes sth like that. The PC should be directly connected via ethernet to the Pepwave device and should be able to communicate with it over layer 2 with GRE. Please note that I don’t want to setup only with VLAN in this case.
