GPS Receiver over WAN Interface
I have a B One (original model with no cellular) and now a 5G Adapter and I’m trying to use the adapter GPS forwarder to the B One as receiver. It appears that the B One GPS receiver function doesn’t listen for this traffic on a WAN interface. Can anyone confirm this is correct?
As an alternative, what you can do is have the B One follow the 5G adater GPS position in IC2.
Thanks, I figured that out after a while. And I have a working kludge by using a port forward on my B One to a linux host on the lan side which redirects the GPS traffic back to the B One using iptables rules. Nothing I try allows the B One to receive the GPS traffic from the 5G adapter directly.
