Can I get GPS position of Pepwave MAX device from API more often than one per minute?
Can you provide detail info so that we can check on this ?
- How long your program/script is set to polling from the API ?
- By default API detect polling times is short (minimum >= 2 seconds) and this will trigger more frequent GPS data collect/sending from the device.
What the GPS location that you get for the polling and within the 1 minute times that you mention ? Can you share us the polling results that you get ?
May i know what you want to achieve using the GPS data API polling ?
