GPS frequency Transit
Dear, what is the frequency of GPS operation?
thanks
Antonio
Hello @asimula,
GPS frequencies are internationally set by the providers of the GPS signals origins (the satellite owners) & not by the GPS receivers (in this case the Pepwave MAX modems).
You can find more on the frequencies used here
If you want a comparison chart of GPS and other navigational satellites & the frequencies they use, have a look here
Happy to Help,
Marcus :slight_smile:
Hi Marcus, thanks for your answer :slight_smile:
